bed cut box build by springer.. what ya'll think
springer
This is the first build log post for me so let me know what ya think. i have a 98 chevy ext cab. got tired of walls and half walls so i did a bed cut. very easy i might add with my handy plasma. this is my 4th or 5th build just for the bed cut, so maybe ill be happy with this one. anyways, enjoy.
old boxes and bed cut...
ghetto amp rack (for now)...
couple of sketch-ups for ideas...
does anyone have any good ideas on how to seal or almost seal the box to the inside of the cab since the bed and cab move independently? i want to try not to lose much through the bed and stuff. thanks.
Your bed and cab still are on the same frame. Bed flex really is not an issue. Unless you plan on using full articulation of your suspension and do some major 4 wheeling the flex isn't even noticeable. I'll show you pics how I bolted up my blowthrough with 14gauge steel.
I have dealt with several blow through sub setups over the years. Forget just trying to extend the port into the cab. All that you will hear in...
Thinking I will go 4th order. 3- 1 if i have the room for it. Motors to the front to help them cool faster.... and we are painting the baskets to...
So im getting the design together for the 2 12's for the truck. Its back from the transmission shop and the burnouts are nice.... so we can get...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
936
springer
springer
Wichita Falls, TX
lowriderram_95
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
