WheresTheButta
First off I'd like to start by saying thanks for all the help and suggestions i've already received.
Now on to the good stuff.
Shopping list:
Morel Carbon Fiber Supreme 6.5" mids
Earthquake "Screamer" tweeters
Knukonceptz Karma Kable 10ga speaker wire
Two distro blocks, 4ga in 8ga out
Stinger pro series interconnects 3'
Dynamat extreme door kit
ARC audio 100.2
--All purchased and now at my house //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
The install began on Tuesday when I took care of fitting the Earthquake tweeters in the stock locations. They didn't want to fit properly so i had to stretch the stock opening a little bit. They are currently hooked up to my JL 300/2 and playing loud =)
Saturday I am going to run the new speaker wire, install the distro blocks, and deaden the doors. I'll then mount the new amp and use my regular speaker wire to power the tweeters while the karma kable will take power to the morel woofers.
I'm hoping the plates that I am using for the JL ZR woofers will accept the morels, otherwise I'm going to need new plates and will be without woofers for several more days.
Shopping list:
ARC audio 100.2
