bazooka ba1500 specs?!
  • 4
Lonnie
6'6 White Giant
I can't find...
750 watt Bazooka amp BA1500 model $130 obo
For that amp. Well found for $75 wanting to get here in a few hours...can't find a lot of info on it aside from a friend assuring me it does above rated which is 750 @ 1 ohm. Yea go ahead and say bqzooka *****...but I'm just wanting my bass in car back and can't afford much lol. Got 4 RE SE-X 10s...ima just put 2 in a sealed.box and call it good enough for now.
Bro that amp is NOT 1 ohm stable. That 750 watt rating is a MAX rating so you are not
going to get that power. (at least not with out frying a coil or 2)
That amp is rated at 320@ 4 ohms and 500@ 2 ohms.
Oo ic...rawr ahh I want my bass back...I'm going into withdrawls lol....trying to find something that will do 800ish @ 1 and is power efficient //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Also there are 3 30 amp fuses on the amp...
Specs say 3 20a fuses. Looking at the pics of the amp, the fuses are yellow. 30a fuses are green.
That amp is an A/B class amp so not so efficient. Stick with a D class amp for efficiency.(at least vs an A/B)
Should be a class d homie, even the lil ba1300 is
in my owners manual for the ba1300 it stated them as class D and the 4 channels and HC amps as Class AB, its different than the one on the web, I didnt read it just found it and tossed it up thinking it was the same thing.
It's the mystery amp :eek:
But yea I repeat...the amp pictured on Craigslist is different than the one on the pdf posted...it doesn't have the Chrome trim or w.e u wanna call it
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Thanks , Ill run it without and see if it drops. If so Ill get another battery.
15
Lonnie
6'6 White Giant
Lonnie
Paducah, Kentucky
Lonnie
    May 16, 2024
    May 16, 2024
