Battery Terminals
Wragold
Ok so im going to bed running 1/0 awg for my power wire and im doing 1/0 awg for my big 3. What kind of terminal can i get to support 2 runs of 1/0 awg wire and my stock wires (see Pixzor). Idk what size the black and yellow wire is but i think its 4awg maybe smaller.
one 0 gauge will use a ring terminal and go onto the top ring, one will go into the 0 gauge hole and the set screw will tighen down onto it, and the stick wiring, cut the end off and insert it into the opening on the left and set screw it in
got corrosion
Thanks I know
Ok U under stood the part with the 0 gauge but the part i didnt get was if the black and yellow wire is 4 gauge how will that fit with the other stock wire in the 4 gauge hole?
thats cool... if you want a battery terminal that costs more than your battery //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Thanks I know
i only see one wire in that pic... i dont know what the hell that thing is thats bolted to the terminal... is that some sort of ghetto fuse holder? what the hell does that go to? take it out
heres a better pic of the wires on the top of the terminal. Idk what it is but the wires go every where so i think there needed. any other ideas?
weird... almost looks like a relay or something that was just bolted on there... is it actually using power from the metal piece that bolts it on there?
Wragold
Wragold
Charlotte, NC
btnhfan
Mike Mccabe
