Battery terminal HELP?
Stillmatic22
Alright guys I need help finding the proper positive battery terminal. I have (2) 4 gauge wires and then I have the factory harness that needs to be hooked up to my battery. Is it ok to use a dual ring battery terminal and put ring terminals on the wires? Also, is there anydraw backs to using these types of terminals. I have one that accepts (2) 4 gauge, but no where to plug in my factory harness.
Can someone please direct me on where to find a terminal that will suit my needs?
Thanks in advance
Do you absolutely need two 4ga runs? can you just run, say one line of 1/0 to a distro block? then you could get the TMC.902k from phoenix gold. Or something similar. Just a recommondation. Let me know if you need a source for install parts and I'll help you out.
I used ring terminals...no problems there.
Another reason to get a deep cycle battery, many of them have two sets of terminals //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif One for the stock wiring, another set for the audio/high-current applications.
Stillmatic22
Stillmatic22
Dallas, Tx
Stillmatic22
