Battery Terminal for 1/0 awg
Looks very good! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Thanks for taking some time to take pics I really appreciate it. No need for ring terminals if I will go with this on the battery side.
yep, the better line of knu products (terminals, distros) all use their kompression system. it kicks ***. you will still need ring terminals for the other ends of the lines depending on what you connect them to.
i have a "konfuzed" or whatever ground distro. i can't imagine trying to figure it out. lol.
there isn't anything to figure out. it's a ground distro, so it's basically a block with multiple openings. follow the directions from the web site and connect wires as needed. as soon as you do one the rest will be cake.
meh. i prefer the set-screw kicker ground blocks //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i'll sell it to you if you want it. i'll never use it.
how in the hell would you do that? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
unless we're thinking different kinds of batteries...
Instead of using the SAE top posts, you would simply use a bolt. That is only if your battery had threaded, removable top posts. Some batteries have studs and you would simply use a nut there. Other batteries come with permanent SAE posts, which would not work with my suggestion.
AFAIK only a few have posts that un-screw. so i was lost. but i know what you is be had sayin.
marine terminals would be the easiest/cheapest IMO
All of the major audio battery brands do have threaded inserts //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
oh. well i don't use "audio brands"
and threaded post FTW //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yeah that is another reason why Optima FTL //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
There is somebody selling a brass set on E-bay that has 2 posts per battery terminal.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=300303409660
SQPL
SQPL
New York
SQPL
