Battery suggestions
REDz28
MI
I need suggestions for battery setups. I will be running a soundstream xxx6500 with two zcon 12" d1s that's about 5300watts rms but I've been told the amp is underrated. Anyway I will be using 0 gauge wiring with a new alt from mike singer 350amps and 200amos at idle. Let me know I've been told batcap 3000 and I can get one for $300
For real? I was under the impression that I'd only need one big one in the front. But I don't have much space to work with I the front for a starter so I figure I'll keep the current battery up there now and but a shurkien 120 in the back. Can I add smaller shurkiens to add power if needed? Or someone know of any deals on batts?
I would use 3 batteries for sure because more than likely the battery set up will get discharged which leads to having a low state of charge battery at some point and a low state of charge battery at some point does not recharge off an alternator as well because it takes longer to recharge. Anytime you are dealing with amplifier power that can out draw your alternator you should have slight overkill on the battery side with a proper external charging system to help keep the batteries topped off when needed.
REDz28
REDz28
MI
REDz28
