I will finally be installing this tomorow or shall i say powering up.
Any opinions on this battery
http://milbatteries.com/hawker/index.html
i know i haved asked before but u have got time to be watching others dont ya think.........
well they cost over $400 but im not sure if they still have these. I picked it up real cheap tho to say the least. I just need a big bad mamajama amp to run on it. It was very very heavy and a struggle getting it in the trunk believe me lolThat thing is a tank... no, it is made for a tank, for real. If it will power a tank, I think you are just fine. LOL. That is one bad mamajama. How much is that thing? Post back with results when you use it.
The Ah rating of only 120 is much lower than I would have thought. Heck and HC2400 is a 128Ah battery. And it is only rated for 350 cycles? Kinetiks are rated for 500 cycles and as audiolife can tell you, there are some that have been pushed well past that number. Even the HC3800 is bigger at 13.25 x 11 x 7 in.ARMASAFE plus
12 Volts
CCA - 1225
Reserve Capacity 240 min
Capacity - 120 Ah C20
Usable Reserve - 70% DoD
Shelf life 30 months @ 25 Celsius
Battery type - Sealed, maintenance Free
Cycle Life - 350
Life (cradle to grave) - 48/54 months
Technology - AGM, sealed recombinant
Internal resistance - 0.0017 Ohms
Transport Class - non-spillable
Environmental designation - Non-Hazardous
Weight - 88 pounds (40Kg)
Size (NATO 6T) - 10" (256mm) x 10.5" (269mm) x 8.9"h (227mm)
Thin Plate
Absorbed Glass Mat (AGM)
Recombinant
Sealed Maintenance Free
Pure Lead/Tin Alloy
Fully charged at manufacture
What is the efficiency of your amps?I paid £40 = to $60 usd. I have just tryed it and its fine. I will be upgrading my starter battery 1st before I pound on this battery and will buy a multimetre to check the voltage before I use it and during its use. The guy I bought it from also had a smaller kinetic and was asking for $30 for it and he was not a car audio man at all, just some 1 having a clear out. It was also one heavy battery and was very small. I should have taken that other battery from him also. I will pm him and see if he still has it.
also the battery has an 06 stamp on it so I take it its about 3yr old already with little use as he said it was used as a stand by battery.
how long could I play this battery for before it goes dead out of interest not that I plan on doing so but will do once in a while if at a show. is the reserve capacity the figure
