Battery placement question
1ndatrunk
Can I live?
I drive a fairly large car( Cadillac Fleetwood) and I'll soon be putting another battery in my car. I have the room to put it in the front opposite the factory location, but will this cause a big problem as far as voltage drops? I'm going to be running about 2300watts total, and everything would be done in 1/0. For batts I'm keeping the large factory one in the stock location, and the other will probably be an optima or kinetic 1400. Can I maintain around 13-14 volts with this, or should I put the second one in the trunk?
Either way around you gotta run cables to the trunk.. with the second batt in the trunk you can do the amp ground to it.. but if you got the room do it how you prefer.. the cables will be about the same total length anyways..
Place in the trunk the battery would help against drops better. Depending on how far you drop now will depend on how ANY battery added will help. If you drop to 11.5-12v now adding a second battery will help keep it more solid in the 12.5 range.
indatrunk
Lol, nice play on words
A Batcap 2000 would work for your application
How much is it?
I drop pretty low full tilt, around 10v, so would I need 2 batts? I have 4g now, but I'll be getting 1/0 VERY soon
1ndatrunk
Can I live?
1ndatrunk
Close
Enellz
