Battery Leakage!
it was hooked up backwards now looking at it...I was just hooking it up for a sec to do a quick test.....still usable now that it is done and is reading out 9v?
goood job!!!//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif now you got a big expensive 9v batt in ur trunk!!
no sh!t...was working too quick and got ahead of myself
it happen's... i wont knock you for that reson... never hooked up a batt wrong..//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif but i have hooked up a cap backword's...//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...
so do you think it is safe to use?
just look over it.. make sure ur case isnt cracked and all that... i would pull it out.. put it in a room temp, room and hook it up to a low amp trickle charger. and see if it holds a charge... if it dose and nothing is cracked ext... then it should be allright..
probably not
mmmmk....so now I am getting mixed answers
if the battery leaked it is most likely a gonner...that's why i said probably not
like i said.. look over the batt.. make sure there are no cracks exct.... put it on the charger and keep an eye on it... to make sure it dosent juice out again... i say if it holds a charge and there are no more leeek's it's all good...
btdickey99
I Hate the Tarheels
btdickey99
Burlington, NC
mdillon
