Battery Junk?
Too bad you don't have a battery tester //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
My brothers car started dying. We assumed it was the battery. But the battery tester said the battery was still good.
So Then I started the car and checked the voltage. The alternator was only doing 12v. Changed the alternator. Now it charges where it should. It may be the battery or could be the alternator.
If it was the alt the battery wouldnt read 14v with the truck on, but it does.
Battery may not be a exact match if you would even begin to understand whats im talking about .The lights may be draining more than you are expecting?know also what are you using to read your voltage output? and where is it located?
English. Lights arent draining anything. Left over a day the new battery measures exactly what it did brand new with nothing hooked up. I read the voltage at the battery with my DMM.
12.7 is what id call ok for overnight voltage. the alternator may not be charging as you think.
&yes the aftermarket lights cause serious drain in alot of situations . you mentioned 12.0 thats low . Indicating charging system is lacking.I let my car sit for weeks and still was/should be 12.3+ With a constant volt meter never turning off.
What battery do you have exactly ?
what dose the votage read after a cold start car off &also after driving for say atleast 20 mins?
12.7 is what id call ok for overnight voltage. the alternator may not be charging as you think. &yes the aftermarket lights cause serious drain in alot of situations . you mentioned 12.0 thats low . Indicating charging system is lacking.I let my car sit for weeks and still was/should be 12.3+ With a constant volt meter never turning off.
Have you read any of this thread?
Clifs:
I left the headlights on
Car wouldnt start
Jumped car
Battery only charged to 12.05v car off
Battery was at 13.x ish v with the car on
New battery was put in
New battery sits at 12.5v car off
New battery sits at 14v car on
Issue is fixed. It has nothing to do with the headlights and nothing to do with the charging system. If it was either of those turning the headlights on would cause a drop from the 14v while the car was on and the battery also wouldnt be at 14v with the car on.
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
