cjj2d
I will be installing a second battery most likely, and is an isolator necassary??
what if you have a stock battery under the hood and a yellowtop in the trunk. Do you need a solenoid? car will alway be running when audio is playing.A solenoid will do the job and for less money. If you aren't running the system with the engine off and the batteries are the same make/model, it isn't needed.
That is where an isolator comes in. The two batteries will interact. Not a huge deal with the car running, but as soon as the car is turned off they will attempt to equalize each other. If there is even the slightest difference between the voltage on the two batteries or their ISR, they will go back and forth with each other and one or the other will usually end up dead.what if you have a stock battery under the hood and a yellowtop in the trunk. Do you need a solenoid? car will alway be running when audio is playing.
