Battery and power supply
I need some advice to add on more power right now I have a set up of 2 15's sxx running on Rockford fosgate t3001bd n Rockford fosgate t800bd for mids
When bass hits certain level amp shuts off for few second I was looking at some of the xs power battery with 14volts because I know my amp recomend 14v is it ok to upgrade 14volt battery on factory car I own Acura tl 2003 or what do I need to upgrade to run on my amp ? any advice is welcome! Thank you
Ok thank you brian84corvette
if you decide to go with more alternator - i can not stress enough how important having the propper "big 3" wiring added to your car is.
i had some cheap 4 guage wiring doing my big 3 and a walmart scoche fuze block at my alt to battery + wire and when i finaly took that junk out and replaced with copper 1/0 guage welding wire the electric in my truck became much more efficent. i was droping to 12s badly with 4 guage - but just by adding propper wiring with GOOD fuze blocks and fuzes my voltage would not drop below 13s ( on a stock chevy 120 amp alternator )
now that ive upgraded to big boy status with system in the truck running over 5k rms total system value i decided a good alternator was in order - as i like to parking lot demo at car shows and random hangout or show off situations - and dont want to be that guy who plays 60 seconds of a song and turns down because voltage stinks = i did alot of homework on alternators and found the "hair pin" style alternator to be superior in every way to a conventional style alternator.
they make better power when hot - and make more power at engine idle situation, lets face it - no one wants to demo a few songs holding their foot on the gas reving the engine to 2000 rpm to keep voltage up... that sounds like a great way to blow an engine to me... so i went with singer hair pin large case gm alt = 220 amps at engine idle hot - and 320 amps at 1800 rpm hot... for a single alternator its worth its weight in gold.
battery reserve is great to have also - but you have to keep your batterys maintained religusly or they will go bad on you. 12.4 is the magic number. at 12.4 volts the battery is so badly discharged that it starts eating itself. the longer a battery sits at 12.4 volts or lower charge = the more perminant harm is done to the battery - and while its possible to de sulphate and recharge - it is still damaging to the batterys to sit at 12.4 and lower charge.
What number should be a good voltage because ive seen many fully charged batteries sit at 12.8
brand new fully charged agm batterys ( in my experience ) sit at 13.1 volts. once they get abused a little 13.0 is still good for them.
i have yet to see a wet ( normal car battery - not agm ) battery sit above 12.8v wich is why its a no no to hook together wet cell batterys and agm batterys.
12.6 is the minimum id like to see any agm batterys sit at if i still wanted to rip on them with audio usage
BassHeadSPL508
BassHeadSPL508
Worcester,ma
brian84corvette
Mike Mccabe
