Battery & Wiring help
jagblazer01
WOOO BASS!!
So im upgrading the stereo again and I will be running 4 2400s in the rear of my truck. I have 2 runs of 1/0 going back there now and dont really want to do 2 more runs. Will I be ok with just 2 runs back or should I do 2 more?
Second part of question lol....I have an 1800 under the hood. Should I isolate the rear batteries or no? If so, would I use 2 isolators (1 for each 1/0 run) or just run both hot wires to 1 isolator?
Or if anyone can point me in a better direction that would be a plus as well.
I'm guessing 2400's are batteries?
What amps are you running?
And as for isolation of your batteries, I don't think ti's necessary. But if you do it, do two isolators. Don't cheap out on important stuff.
Yeah, 2 runs of 0/1 AWG will have the ability of running upwards of 600 amps. W = (V*A) = W = (12*600)
W= 7200 Watts.
That's if you have a 12v system. But you probably have a 14 or 16 volt current. So, your system can hold more. It's all depends on your alt at this point.
jagblazer01
WOOO BASS!!
jagblazer01
Baltimore, MD
IDSkoT
michigan born
    May 14, 2026
michigan born
    May 14, 2026
