UNI-T-UT203 ive been using this model for about 7 years almost daily very nice for the money. (Edit mine is a 204 http://www.ebay.com/itm/UNI-T-UT204A-Digital-Handheld-Clamp-Multimeter-Tester-DMM-Voltmeter-Amp-AC-DC-/261813739440?hash=item3cf5509fb0:g:3~0AAOSwBahVBpiu )Under $100 isn't bad then. What model do you use?
Uni T UT203 Digital Clamp Meter AC DC Volt Amp Ohm Hz Duty Cycle Diode Cont DMM | eBay
You should disconnect your second battery before trying to isolate your problem.
I guess it should go without saying but when testing batteries test each battery separately. A weak battery well pull down a strong battery.
