SOLD Batteries! C&D Technologies, 100lbs, puts HC2400 to shame...
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
Still have a few of these C&D batteries left. 100 pounds each, 134.8ah, threaded inserts for easy use of bolts/ring terminals. Resting voltage sits right at 12.8V and stays there for a very long time. I have personally used these and gotten a better score over my HC2400's and Batcap 2000's...these actually have the same ah rating as a HC3800, which go for around $450 on ebay.
$180 each local, $250 shipped each, discount for multiples.
Detailed info: http://www.battery-usa.com/Catalog/ups12475.pdf
If I had any money I'd actually use these for something... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
428
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
