Bass knob
Set to max, then set gains on amp.
Sent from my SGH-T999 using Tapatalk
thats for passive gain setting. There is active gain setting method for bass knobs but its for more advanced users only assuming the bass knob is a proper gain knob that goes up at proper levels vs having a 15% to 100% power dump immediately after a certain point halfway.
I feel like my sundown one is like that. Past 20% it doesnt add alot but 0-20% is drastic
So what u are saying that I should set my gain a little advance because I have my gain set but I don't get nothing from the knob.
Sent from my SM-T330NU using Tapatalk
You want your gain knob(bass knob) to be at 100% when you set your gains on your amps so you can turn down your gain when needed as well as never go past 100% into clipping
I kind of loss I set my gain with a mm using 40 hz an I had my control knob at max but I don't here no different from min to max
Yes and there is a light on the control knob when I start the car
What amp, what sub, what kind of box? ported or sealed?
If you disconnect the knob and play your music, is there a difference in output between little gain and alot?
and just for an fyi, this is how gains work.
Prime rockford r500x1d sub nvx vsw124v2 I am using a port box 1.75 no different if I remove the gain I have the set 3 an 4 my gain go from 1 to 11
imiguenes
imiguenes
US
imiguenes
