wilzyx
village idiot/racist
if your using a bass knob, shouldnt you set the gains on the amp with the bass knob turned all the way up?
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif Please stop...I would set the gains with the bass knob not plugged in then after setting the gains plug it in.
ya bass boost is teh suxor, but all it says is remote bass knob so im not sure. its probably boost though. its a kenwood amp if that makes a difference.If it is a gain/level control, yes. If it is a boost control, no. Throw the boost control away lol.
could i just play around with the knob while im setting the gains, or would the bass boost have an effect on the voltage also?IIRC Kenwood does not use a level control on thier amps. See if you can get them on the phone. Tech support would know for sure.
If you can't find out for certain, you can always leave it disconnected.
The bass boost will increase/decrease voltage while you play with it. If you want to use it, and it is a "boost", set it with it as high as you would use it. And don't turn it up past that.could i just play around with the knob while im setting the gains, or would the bass boost have an effect on the voltage also?
