Basic Questions About Sub System
Mr Jaderman
Hey all,
I just bought 2 Pioneer 12" 400W nominal power, 1400W max power DVC drivers. I was wondering if I hook the drivers up in series do I get 800W and then need a 800W amp? Or they both would still be 400W? Also, since its dvc, I can wire it up as 1 ohm or 4 ohm, whats ideal? Or does that just give me more flexibility in choosing an amp?
Thanks in advance!
Speakers don't have Watts, they take in Watts. If you have 2 400watt subs, then yes to power them you'd want 800watts. Go for 1 ohm.
Look for an amp that does 800-1000 Watts RMS at 1 ohm. Don't even look at peak. Peak is for advertising.
the lower the impedance the more stress on the amplifier and the your electrical system, but it is easier to produce power at lower impedances. As long as you dont go below the recommended impedance of the amp, you're fine. Also distortion is greater at lower impedances but you will more than likely not be able to hear a difference in terms of sub stage
https://www.amazon.com/dp/B01EXOTD56/?tag=caraudiocom-20 Cant go wrong with these for the price and drop ins on HU power alone. They do much...
As for your setup, the circled input in that reply is where the LOC (built into the amp) is located. You don’t need a LOC other than that. All you...
35
4K
I can't speak to carplay but I'm using a Joying unit for android auto. It's a single din slot with a screen that attaches. The single din units...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
338
Mr Jaderman
Mr Jaderman
United States
Mr Jaderman
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
