Bandpass, this true?
its going to sound like shiiiiiiit
each 12 will be in .79 cubes be4 sub displacement....so if u put a sx12 in there which is .16cubes of displacement
your down to .63 cubes per 12......heeeeeellllllllllllll to the naaaaaaaw
thats space for a 10 inch sub
so u have 2 12's in its own .63cubes of sealed space playing into a 1.78cube ported area....i doubt if port displacement was calculated
so its going to be less than 1.78cubes
80
Prefab and bandpass are two things that should never be discussed in the same context. The design of a bandpass has to be based on the sub going in it. The chance of the sub you plan on putting in it being the one the designer used as the basis for the design is somewhere in the neighborhood of zero. If you want a bandpass get someone to design one for you and either have them build it or build it yourself from the design. If you really want to learn, research bandpasses and design your own.
x2
bestbuy isnt the smartest group of people, theyre just a retail store... theyre in the business to make money, not to make the most badass system ever seen.
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
phantom240
Mike Mccabe
