Bandpass Help for 2 18"s in a wall
  • 2
savagebee
sociomagicologistics
2,937
OK 918
I just got done building a 7.5 cu ft after displacpement sealed box for 2 18"s
I realized that I could easily make a 4th order bandpass out of this due to my cars internal configuration
so, what size and tuning of a second chamber would I need?
Im wanting a low roll off, with good SPL
First and foremost I want it to sound good, but I also want to be able to get loud as hell on command
This would end up being a wall behind my second row of seating
Thanks in advance
Sealed chamber is a little too big. Might want to shrink it so each sub is in around 3-3.5 cubes each.
Somewhere around 15-18 cubes for the ported chamber.
Go for anywhere from 325-400in^ of port, depending on the size of the ported chamber. Tune to around 45hz.
That should be a good start, you should be able to figure it out from there.
well, unfortunately thats bigger than I can manage
the 7.5 cube box is going to stay, but I can place some wood, fill, whatever to shrink it down
I was playing with win ISD last night, and the plot of my 7.5 sealed into a 5 cube vented to 50 looked nice and flat with a good peak at about 65 I think, which is my cutoff
this seems small to me, with too high of a tuning so looking for some input on this setup
also, this is a wall behind second row of seating, it gives me cargo space in the back, and I can still keep my babyseat in the back
this is why my space is limited even though its a wall //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I hope you didn’t misInterpret my last message.. I was excited that I actually understand what you’re talking about… Lol! I will level with you. I...
14
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
savagebee
savagebee
OK 918
savagebee
