+1it's not the woofers distorting its the lamesauce signal that the amp is feeding them. I guarantee this.
You're more than likely pushing the amp too hard, causing it to put out dirty power.:-( im going too buy the 500w type r's because my 400w kenwood subs can't handle my amp. They distort when I turn the volume up past 85% or the gain up any higher than 60%
Some MTX amp with the Xtant cooling tech.hey toronto , what amp is that in your avatar? Looks pretty cool.
They sound perfect up until a certain point and then they get this sort of hollow sound.. My buddy has the 9104 and the same subs and his amp is cranked all the way up and his boofers don't make that sound that mine doYou're more than likely pushing the amp too hard, causing it to put out dirty power.
Where the gain is set, very much depends on the signal that is being fed to it. A lower voltage signal would require a different gain setting than a higher voltage signal going to the same amp, assuming the same load on both.They sound perfect up until a certain point and then they get this sort of hollow sound.. My buddy has the 9104 and the same subs and his amp is cranked all the way up and his boofers don't make that sound that mine do
Or we could thread jack this and steer it off on tangent.I say we stop entertaining the continuation of this thread until OP starts referring to his speakers as A: Speakers , B: Subs (Subwoofers) , Or C: Woofers.
Boofers just sounds ghey , i would never ride around with boofers in my car. LOL
agreedI say we stop entertaining the continuation of this thread until OP starts referring to his speakers as A: Speakers , B: Subs (Subwoofers) , Or C: Woofers.
I made up the word boofers because like this, suBwOOFERS. i cant believe you all really hate it that much.. I think its an awesome thing to call em.I say we stop entertaining the continuation of this thread until OP starts referring to his speakers as A: Speakers , B: Subs (Subwoofers) , Or C: Woofers.
Ok great, thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I'll get the alpine 1222s then.as long as your not clipping them, then under powering will bring no harm, but if you are unhappy with the output and start cranking the gain to make up for it you will burn up the subs
and boofers is probably the worst name for a sub that i have ever heard in my life //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
