bad to under power boofers?
Their **** is CAE certified tho
That only means that the amp does in fact output the rated 500w at 4Ω.
The claim of 900w @ 2Ω is completely unsubstantiated, and out of scope of CEA2006
In 2003, the Consumer Electronics Association established standard CEA-2006, "Testing & Measurement Methods for Mobile Audio Amplifiers." This "voluntary" standard advocates a uniform method for determining an amplifier's RMS power and signal-to-noise ratio. Using 14.4 volts, RMS watts are measured into a 4-ohm impedance load at 1 percent Total Harmonic Distortion (THD) plus noise, at a frequency range (for general purpose amplifiers) of 20 Hz to 20,000 Hz. Signal-to-Noise ratio is measured in weighted absolute decibels (dBA) at a reference of 1 watt into 4 ohms.
***edit*** - by "completely unsubstantiated", I should have said - "not third party verified".
Oohhh..
They also shut down when played at 2ohm continuous.................................
Should I stock with the old version of the type r?
thats not why he had that response, im guessing it was the same reason i did,
the fact that you said that you would be cranking up your gains, which means you will be clipping the amp, which will shorten the life span of your sub/s greatly,
one of the unwritten rules of car audio. the gain is not a volume knob.
:-( im going too buy the 500w type r's because my 400w kenwood subs can't handle my amp. They distort when I turn the volume up past 85% or the gain up any higher than 60%
Vagomire
Vagomire
Rockford, IL
ciaonzo
