bad SQ from HU, help
fatryan
Banned
I just got a cda-9855. my old deck was a deh-550mp. i liked the sound of my pioneer, but i wanted the features of the alpine. now i got my alpine and it sounds bad. i cant figure out where the bass and treble settings are. and i dont understand the EQ. its a 7 band EQ, and its NOTHING like my pioneers 3 band EQ. also, does any1 know if the "Media Xpander" is a good thing to use? will it send a dirty signal like Pioneer's "loud"?
OK you have to hold the MENU button for 2 seconds or whatever then you can make your own EQ....7band graphic or 5 band digital parametric..I use the 5 band... and to save the settings you have to hold the glidetouch for 2seconds on P1 -P6 (pick one)....if you use the 5 band press BAND to change the freq's and press SOURCE/POWER to change the width of the change then use the volume knob to change the LEVEL of the freq
you can also use iPersonalize...from alpines website and set it how you want the EQ and everything.... and just put it on a cd and bam!
I use the MX on level 2 for CD, CDWMA but 3 for Radio....mainly it boosts bass and highs ...no mids...I will eventually turn it off once I get my (3) GTO804's in
I have the '53 btw...mine sounded "bad" at first cuz I was used to my EQ on my P7600MP but the Alpine has opened up my lil 4.5" bose
You will get it eventually...took me two days
OK you have to hold the MENU button for 2 seconds or whatever then you can make your own EQ....7band graphic or 5 band digital parametric..I use the 5band...
i know how to change the EQ, how do u change bass and treble?
congrats,you just purchased the single most unuser friendly HU ever made
You and your '33....//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Increase as in change level or change the width?
change level i guess. it goes from like... -6 to +6 i think..per band. and when i mess with the lowest one, the highes die, and vise versa. this EQ is totally different from my pioneers EQ. im at a total lose on how to set it right.
fatryan
Banned
fatryan
Southampton, Pa
Slaugh
michigan born
    May 14, 2026
michigan born
    May 14, 2026
