bad rca input or rca cable itself?
M@nJo
bay area
I been running this 4-ch power acoustik amp for my front stage and rear fill for 2 years using the same rca cables. Few days ago, I noticed channel 1 (driver-front speaker) would make crackling noises and eventually turn completely off. I checked the connections, mess around with the rca cable and it works back to normal. But will eventually do the same thing after few minutes. Is it possible for the RCA input on the actual amp be bad or is more likely the RCA cables itself? How common can it be for an rca input to go bad on a amp?
rca jacks can break, and cause the sound to cut out... the legs that go into the board snap, and cause it to get a good connection sometimes, then cut out all together...
its a easy fix.....pm me
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
M@nJo
M@nJo
bay area
ampjunkielikeme
    May 22, 2024
    May 22, 2024
