Why are we fighting over this? Simple as this:If it works for a persons specific case, it works.
If it doesn't, it doesn't.
You're the one bringing up power over and over. We understand that you're looking for 750 watts. What we're trying to tell you is that regardless of the price and power output, the amps are inefficient, introduce noise, and are all around poop. You're risking your entire electrical system by running this amp. You're risking your new subs. You're risking your battery. Your alternator. Hell, it could start a fire. Do you have the proper fire extinguisher in your vehicle? Do you think buying an amp that's $50 cheaper than quality(relative to Audiopipe, at least) amps is really worth risking all of this?
F
uck yes, I'm sensationalizing. It doesn't make any of this incorrect. Inefficiency creates heat. Heat is bad.
You probably won't notice the noise, and if you end up upgrading to a quality amp down the line, you'll likely not hear a difference. However, if you were to clone your vehicle as it is, and used a quality amp in one, and that AP in the other, you'd notice a difference.
And you need to realize the difference between people who have used Audiopipe and don't know better, and people who have used Audiopipe and know better. The people who don't know better will go around toting, "It's tiny and makes my subs go boom!" while the ones who know better will sell it/throw it away and say, "Wow, that amp should not have been so hot. And did you hear that constant buzzing? What was that all about?" Like others have said, do what you want; we don't have control over you and your purchases. You're the one making the mistake.
