hispls
LOL. Now OP learns to wire to 2 ohms and overdrives the amp trying to push it to half ohm volume levels.
Just rewire it and see what happens... I'm on my way to work right now. Someone will help tho. If not, I'll hit you up around 10pm.No wonder it was getting so hot. Sorry my french but HOLY ****. Do you think it's damage to a bad point? and what about the sub?
post with the picture actually made me giggle because when I read it, I actually wanted to facepalm.LOL. Now OP learns to wire to 2 ohms and overdrives the amp trying to push it to half ohm volume levels.
Alright thanks man!Just rewire it and see what happens... I'm on my way to work right now. Someone will help tho. If not, I'll hit you up around 10pm.
Thanks. I'm hoping that because it did protect, it saved itself from serious harm and will still work good.Just rewire it and see what happens... I'm on my way to work right now. Someone will help tho. If not, I'll hit you up around 10pm.
That's what you're doing now that will break your amp if you don't knock it off.Alright thanks man!
Can someone tell me how to wire or to see if this is right?:
Connect the negatives together, and put it in the outside negative speaker terminal. Connect the 2 positives from subwoofer and put it in the outside positive speaker terminal?
Like that ^?
That will double the ohms from 1 to 2 right? Like it doubles 2 to 4 in that example you showed?That's what you're doing now that will break your amp if you don't knock it off.
Do this:
imma cut you so bad if you dont let me know what you want on trade. facebook meGoddammit just listen to advice u cawk sleeve
I'm sure he's right. I just wanted to kind of ask and see why you wouldn't wire it the way. I just want to learn why and how things work. Obviously I don't know, or I wouldn't have wired my amp to .5 ohms lmao.Goddammit just listen to advice u cawk sleeve
