AudioControl ESP2 - Worth it? ASAP
  • 5
does it have a dial under the 2v led? my friend has the eqx and i had the eqt's they work as line drivers..thing to remember is even though they can get "8 v" (believe they say high as 13)is that they prolly wont lol most i could get to boost cleanly was 5.5 volts from 3.9v then i got smart and used an amp as a line driver lol
Ok i got a message for someone in here ........ I LOVE YOU AUDIOLIFE !!!!!!!! And will help you with all the car audio stuff you got .....You are very special to me and i love you forever ....Kat
Originally posted by audiolife does it have a dial under the 2v led? my friend has the eqx and i had the eqt's they work as line drivers..thing to remember is even though they can get "8 v" (believe they say high as 13)is that they prolly wont lol most i could get to boost cleanly was 5.5 volts from 3.9v then i got smart and used an amp as a line driver lol
No, it does not have a dial. I know the models which you refer to, and mine does not line drive. :p unfortunately //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
729
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
Mark_ab
The Alpha Male
Mark_ab
Edmonton, Alberta
audiolife
