Audio Set
  • Thread starter unrhymed
  • Replies 0
  • Views 449
unrhymed
hey guys I'm new to the forum and to car audio but I am planing to buy 600$ worth of car audio soon.
I have nothing in my car for audio so I have to buy from stratch but I needed some professional help or someone experienced to tell me I am doing things right.
First of all I own a 1992 Dodge stealth, and I am buying my pieces from OnlineCarStereo.Com
I was not sure if these pieces will correspond with eachother or I am wasting money.
heres the list.
Boss Audio BV6000
In-Dash DVD/MP3/CD Receiver with AniGraFx Display 129$
Technical Specification
* WMA Playback: Yes
* Satellite Radio Ready: No
* Subwoofer Preamp Outputs: No
* MP3 playback: Yes
* Maximum Power: 4x80 Watts
* HD Radio: No
* DIN: 1
* CD Text: Yes
* Bluetooth: No
* Aux input: No
* Built-in EQ: Yes
* CD-R/CD-RW Compatible: Yes
* Remote Control: Yes
* Detachable Face: Yes
Features
* ISO DIN mounting
* Full detachable front panel
* Oversized, AniGraFx display
* PLL Synthesized AM/FM tuner
* 24 station presets
* Switchable USA/Europe/Asia radio frequencies
* DVD, MP3, CD-R and VCD compatible
* NTSC/PAL compatible
* Illuminated controls
* Preset EQ response curves
* Separate bass and treble
* Balance and fader controls
* Loudness
* Stereo/mono switch
* Local/distance switch
* Mute function
* Last position memory
* I-Bit D/A converter
* ESP (anti-skip mechanism)
* Dual (front and rear) RCA outputs
* Subwoofer output
* Wireless remote control
* Output power: 80W x 4 channels
Boss Audio OHC694
6" x 9" 900W 4-Way Car Speakers 65$
* Sensitivity: 95 dB
* RMS Power Range : 450 Watts
* Peak Power Handling: 900 Watts
* Impedance: 4 Ohm
* Frequency response: 40-20000 Hz
* Design: 4 Way
* Woofer Composition: Poly Injection
* Tweeter Composition: Silk
* Diameter: 6x9 Inch
Features
* Diecast Aluminum Frame
* 80oz Magnet Structure
* 1" Aluminum voice coil
* Poly Injection Woofer Cone
* 1" Silk dome
* Priced per pair
Crunch P1800.4
1800W 4-Channel Powerzone Series Car Amplifier 125$
* RMS Power Range : 225-450 Watts
* Number Of Channels: 4
* Maximum Power: 1800 Watts
* Built In Crossovers: Yes
* Channel Separation: Yes
Features
* 2/3/4 Channel operation
* RMS Power @ 4 Ohm: 900W x 2
* RMS Power @ 2 Ohm: 450W x 4
* RMS Power @ 4 Ohm: 225W x 4
* Bridgeable amplifier topography
* MOSFET outputs
* Illuminated Crunch logo
* PWM digital power supply
* High-level inputs for OEM radios
* Fully adjustable crossovers, Hi-Pass and Low-Pass.
* Silver RCA line inputs & outputs - permit amplifier daisy-chaining
* Silver power connections
2x SoundStorm STS12D 43$ each
12" 1200W Dual 4-Ohm Subwoofer
* RMS Power Range : 600 Watts
* Peak Power Handling: 1200 Watts
* Impedance: Dual 4 Ohm
* Low Frequency response: 28 Hz
* High Frequency Response: 2000 Hz
* Diameter: 12 Inch
Features
* 120 Oz. Magnet structure
* 2" kapton Voice coil diameter
* Poly-coated paper cone
* Santoprene surround
* Dual high temperature kapton voice coils
* Mounting depth: 6-1/4"
* Priced per speaker
Sony XS-L120B5D
Dual 12" 2000W Ported Subwoofer Enclosure 199$
* Sensitivity: 89 dB
* Peak Power Handling: 2000 Watts
* Impedance: 4 Ohm
* Low Frequency response: 20 Hz
* Diameter: 12 Inch
Features
* Two 12" five-sided polypropylene woofers with rubber surrounds
* MDF construction with black carpet covering
* Pre-wired 4-ohm mono enclosure: Great for mono or bridged stereo amplifiers
* Unique cone design offers superior rigidity
* Gold-plated 5-way Binding Posts
* Gold-plated Binding Posts
* 4-Ohm voice coils
* 32"W x 16-1/16"H x 18"D1 x 15-1/4"D2
So if you have noticed the price is around 600$, and there is no speaker wire or wiring there, thats ok cause I can get that later, but I wasn't sure if I am getting my moneys worth or maybe I have a piece that wont give my system all its power.
Thanks guys, if you can help me that would be great. I have 0 experience with car audio.
Tips and help would be great!//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
unrhymed
unrhymed
Canada
unrhymed
