why can you use less SQ inches of port per driver in a unibox
vehementSPL
I am curious why for example... In winISD
I take 2 12's in 5 cubes ported and 100 inches of port it gives me X amount of port velocity . Now explain this. If I do 8 12's in a unichamber that is 20 cubes ported with 400 inches of port. So everything exactly 4 times so should hold the same port velocity.... The big unichamber box has a hair less than half of the port velocity . Now I know WinISD won't be 100 percent accurate on the port velocity BUT it has to be following some theory that I am not aware of (never really got into uniboxes)to show that it doesn't match the same velocity but exact same multiples of everything else. I even tried 4 100 inch ports in the unichamber box and still shows less than half as opposed to the smaller box with 2 12's. Any input.
Not true. Each doubling of radiating area will theoretically add 3 db if volume per driver remains the same, and the total supplied power is the same. Now if you double power, then you see a theoretical maximum 6 db increase, which is roughly a doubling of output.
because its sharing airspace between each driver, which effectively reduces the amount of airspace needed overall.
example
12" sub needs 2.5 cubes
2 12" subs need 3.5-4 cubes
3 12" subs need 4.5-6 cubes
cut the box with 8 12s down to about 15/16 cubes, should work well.
also in terms of port area, 12-16 in^2 per cubic foot is a good rule of thumb.
example
Not true at all.
That is what I was saying
vehementSPL
vehementSPL
indianapolis
mjf
