audio competition
Kazshell
Alright here's the story, me and my boy are both in Iraq right now and we have been arguing about who's gonna have the best setup for about 6 months and I decided to bring it to yall and maybe you can help us solve this issue, until we get back in about a month and can have a battle.
Heres the setups
My car : Dodge Ram Single Cab
H/U : Alpine CDA-9887
Subs : 3 10w6v2 + Sealed Box
Amps: 3 JL 500/1v2 Per SUB - JL 300/4v2 for Components
Components : Infinity 60.9 CS 6 1/2
Alternator : Custom built 200A
Wiring : 1/0 AWG
His Car : Pontiac GTO
H/U : Pioneer D3
Sub: Pioneer Premier TS-W5102 SPL
Amp : Pioneer PRS-D2000 SPL
Other Spkrs : Factory Blaupunkt
Wiring: 1/0 AWG
I explained he will probably beet me in SPL but I will kill him in SQ
He doesn't think so.
my bad, the best overall.
He say's his is gonna sound better but I keep telling him his setup isn't gonna compare to mine overall. all he's got is SPL
his Sub is a 12'', forgot to put that
you should be louder. more cone area, same power, and you dont have to put it in a trunk. im also pretty sure your front stage will beat the blahhpunks.
If he thinks his is better after hearing yours he is deaf //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thats kinda what I was thinkin, I havent ever heard a pioneer sub that ever impressed me and where I'm at we gota go with specs. On specs I was thinkin he would blow me away since im runnin 10''s.
Anyone ever hear the Pioneer Premier TS-W1025 SPL? I know they hold a world record and all that
I'M THE PERSON KAZSHELL IS TALKING ABOUT I'M ONLY RUNNING ONE SUB CAUSE IF ANYBODY HAVE A GTO U KNOW HOW LITTLE TRUNK SPACE I HAVE.NOW LETS GET DOWN TO BUSSINESS......... ARE YOU GUYS SERIOUS YOU CAN GO TO THE JL, MTX, KICKER SOLO X, OR ANY OTHER SUBS YOU HAVE OR THAT YOU DREAM OF HAVING GO TO THEIR WEBSITE THEN GO TO PIONEERAUDIO.COM LOOK UP TS-5102 SPL SUB (OR JUST LOOK BELOW) AND PRINT BOTH SPECS OUT THEN TELL ME WHICH ONE IS BETTER I'M NOT SAYING THAT JL OR ANY OTHER ONE OF THE SUBS I METION SOUNDS BAD THEY ALL SOUND GOOD BUT COM ON GUYS LOOK AT THE SPEC ON PIONEERS THEY ARE A FREAKING BEAST..... POINT BLANK!!!!!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Size 12"
Woofer Cone Material Interlaced Carbon Fiber Reinforced IMPP Cone Woofer
Surround Wide-Roll, Woven Aramid Fiber Radial Rubber Surround
Overhung Surround Design
Voice Coil Dual 3 in, High Inductance, 6-Layer, Long Voice Coil
Voice Coil Wire Ceramic-Coated
Voice Coil Bobbin Pure Titanium Voice Coil Bobbin
Damper (Spider) Precision Dual Damper
Damper Ring Yes
Top Plate Thick 1.2 in (30mm)
Projected Pole Yoke with Vented Pole
Aero-Dynamic Magnetic Gap Design
Magnet Construction Massive Triple Stacked (320 oz.)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket (None)
Wire Terminals 8-Gauge Wire Terminal
Specifications
Watts MAX. Music Power 6000 Watts
Watts Nominal Power Handling 2500 Watts
Frequency Response 18Hz ~ 2kHz
Sensitivity 88dB
Ohm Rating DVC (1ohm or 4ohm)
Recommended Enclosure 1.5 Cubic Feet
Dimensions 327 (Diam.) x 304 (mm)
Mounting Depth 266 mm
Kazshell
Kazshell
Savannah, GA
PIONEER JUNKIE
