Audio battery
Jagger Ruffin
CarAudio.com Newbie
I am going to be running a 2ohm subwoofer at 1000 watts, and 4 4ohm door speakers at 300 watts a piece, both with separate amps. One amp is 1500 watt, and the other is 1320watt. If anyone has any recommendation on what kind of audio battery I should run for this setup, it would be appreciated.
  1. Not right now
Depends.. Is your alt bigger than a softball? Any electrical upgrades?
What's the name of the amp(s) you will be using and what ohm load will you be running? Also what car?
If your car already has a decent battery/alternator, you'd be better off getting a big three kit
Jagger Ruffin
CarAudio.com Newbie
Jagger Ruffin
United states
vegang
vegang
