myjaja
Audioque
- Thread Starter
- #16
Youre saying to use a big enclosure if I was to run two sundown saz-3500's? on those aq's?Well if you gonna get another 3500 stick to the aqs for now they should take 3500 on music..Depending on how low you gonna keep it tuned you might be better off with a larger box and more port area to make it peak harder around tuning if thats what your going after..
I'm about 99% positive your gonna peak in the high 40 to low 50hz range..
Play with you tuning just a bit, try 36 see how you like it they will still have some killer low end and should give you a boticable gain closer to the cars res frequency..
Also, Im an idiot. I thought that "Vas" was the sub displacement which it wasnt. So the enclosure that theyre in which I thought was 5.2 net and tuned to around 34 hz is inocorrect. Its probably sitting around 5.8 net and tuned to 33 hz, as the subs are also on a double baffle as well. Thats a pretty big enclosure and extremely already over sized. The subs are liking it though. lol
Im going to build a new enclosure though once I get the second amp. Ill tune it to 36 like you said and that was my original plan as well.
