Atomic apx with 4" coils?
4in coil doesn't mean louder..
Your looking for high displacement drivers..
What you tuning to?
Your cars going to peak around 47 to 50 for comps..
F3 should occur around 28 from natural cabin gain..
Putting another 3500 is going to kill any singal alternator..
You need at least a 250 amp alt and 2 huge batteries..
They key here is efficiency in design then displacement capibilities then power handling..
4in coil doesn't mean louder..Your looking for high displacement drivers..
What you tuning to?
Having a 4" coil pretty much means it can handle more long term. My friend was the one that recommended me getting that one though. Im currently tuned to 33-34 hz with my two 12" aq hdc4's. Im doing a 151.6 with those subs off music on a single saz-3500. Im also planning on getting a dc 270 amp alt once I get the second sundown saz-3500.
My goal is to have a loud daily trunk car doing at least 153-155 off music with a low tuning.
Well if you gonna get another 3500 stick to the aqs for now they should take 3500 on music..
Depending on how low you gonna keep it tuned you might be better off with a larger box and more port area to make it peak harder around tuning if thats what your going after..
I'm about 99% positive your gonna peak in the high 40 to low 50hz range..
Play with you tuning just a bit, try 36 see how you like it they will still have some killer low end and should give you a boticable gain closer to the cars res frequency..
I'm about 99% positive your gonna peak in the high 40 to low 50hz range..Play with you tuning just a bit, try 36 see how you like it they will still have some killer low end and should give you a boticable gain closer to the cars res frequency..
How the fuck are you going to know that without knowing what he drives? There are also plenty of people out there running 7kw+ off a single alt, myself included
He has videos, lmfao
if you running 7 kw off a single amp your killing you electrical system..
7k@80% efficiency that's around 9000 watts of draw on the alt/batteries
P/V=I
P= power in watts
9000/14=642 amps of draw.
If you have a 300 amp alt your batteries have to discharge 340 amps.
I didn't say it's not possible but your gonna damage the equipment..
What does your voltage drop to?
Main reason you get away with it because music is dynamic.
My rs 1750.1s do about 3900 @1 ohm strapped with 2 2400s and a stock alt but it drops to 12 volts..
I measured around 360 on lil John-throw it up..
I could play it all day but eventually the alt/batteries breakdown..
Windings get too hot etc etc...
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
RangerDangerV2
