Atomic 5000.1 Help
Isnt that Stetsom a 4000 watt amp?
I cant remember
Dante might try to tell you it is //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
2k6 is rated for 3000 @ 2 ohm on 13.8 volts. I clamped it doing 2924 @ 0.95 ohm on 12.3 volts on a 0.5 ohm nominal load (same dual 1 9515)
They say the 2kd will do 4kw?? i dont know if it will for sure, but the 2nd gen AT5000.1 is alot better amp then the 1st gen AT5000.1, stronger and more reliable, the 2nd gen has 44 caps and 4 torroids vrs, the 1st gen with 36caps and 2 torroids! The 1st gen will do close to rated power, and the 2nd gen will do over rated power for sure, as thats been tested!
1st gen have 2 transformers on the power supply as with the 2nd gen has 4 transformers (dont know if thats the correct word for the part) Anyways your at .5ohm with box rise you should be around 1ohm or a tad higher with your burp tone trust me I have played with both generations as well as the 7k set it to 73-80vac with using 3vac first with bass boost.
I always called them torroids, or how ever there spelled, but yes transformers!!
Any odds on it blowing up on me? //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif I will gain it up tomorrow...
gen 1s had problems with strapping so if you dont strap it, it should be good to go.
And what did you do for a score with the 10s in your REX??
the score is on the db numbers section BTW, the spiders ripped apart on both subs //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif but it was chinese made //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif Getting recones soon with american spiders //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I never had a problem with the original spiders on the HDs so thats what i requested on my recones. But im retired now that I sold my amps, so im just getting the recones on and selling them //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
SeanDub
SeanDub
Kansas
dtbrown
