Atomic 5000.1 Clamp Testing
craftsman clamps, especially the cheap ones, arent really that accurate. figured id throw that out there.
Take the results however you want. The owners manual says it has +/- 5% uncertainty for the AC current measurement. That means the current reading would be between 53.865 and 59.22 (+/- 5% from 56.4). That means the power could be between 3819 watts and 4199 watts, not considering the uncertainty of the AC voltage reading because I don't have that manual.
But let's assume it is also around 5%. Therefore, that reading could be between 67.355 and 74.445. Therefore, coupled with the uncertainty of the AC current reading, the power could have been anywhere between 3609 watts and 4409 watts.
Then we can look at the impedance the power was produced at. That calculation is voltage/current. So that impedance could have been anywhere between 1.14 and 1.38 ohm, which isn't much of a difference.
So, the meter does have uncertainty, as does any meter, especially a meter to be purchased by a consumer/enthusiast. Your comment begs the question - how many of these clamp tests are worth anything? Because then you get into real power vs. imaginary power, power triangles, and the issue of impedance rise introducing imaginary power.
Meh, I don't think there is a sticky or anything. You need a true rms clamp meter and a dmm. Hook the DMM up to the pos and neg leads coming from the amp and set it up to measure AC voltage. Clamp the true rms meter around the pos lead coming from the amp and set it to measure AC current. Multiply the two numbers together to get power. Divide voltage by current to get impedance.
Where is this print screen button? Lawl
If your on a laptop, you might have to push the fn button and one in the top right corner.. it says "prtsc" on mine right on top of sysrq.. I have a toshiba cheapy laptop, right next to pause and break which is one button.. and insert and delete
SeanDub
SeanDub
Kansas
SPL15
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
