at a crossroad need help!!
fcivc24
Im in the process of upgrading my whole system but Right now I have 2 rf p3s in a sealed sub box with approx .65 per chamber the subs are wired in parrel they are being powered by a rf 800.2 amp.. and it doesnt sound quite as good as i would like, so i have been thinking about having a custom ported/slotted box made or get new subs and keep the same box!! what do you guys think? will sound better
these are the subs i have been looking at
2 10" diamond audio d6s
2 10" infinty perfects
2 10" alpine type r 1500 watts
2 10" MA Audio subs
which ever ones sound the best for the money and be able to be pushed by my current amp
0r maybe 1 12" sub but has to be atleast comparable to 2 10s!
thanks for your help
I personally say the Diamond's
Good SQ and they have good output
Do the two 10's in a nice little ported enclosure on your amp, you'll be happy
Get two DVC 4ohm subs, run a sub on each channel, 400wrms to each //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Diamond audio gets my vote
Followed by the Alpines
Then Infinity
And finally MA audio.
What kind of amp do you have and whats the budget?.
im trying to stay away from getting new subs and a new box. the box i have right now with the p3s is a sealed box with .65 ft per chamber but if i absolutly have to then i will. Are diamonds good subs? are they reliable?
Diamond audio gets my voteFollowed by the Alpines
Then Infinity
budget is around 300 hundred
amp is a rf 800.2 i have it bridged too
I have never heard diamonds! Do they get pretty low?i have heard the type r and they hit lower then my subs did but he was using a mono block amp as well
i'd say get the D6's and either build a bigger sealed box....or have someone hear on the forums build you a ported box (or you can do it and have someone supply the plans)
here Is what Im going to do im getting a new ported box regardless
and for subs here is what I have found
10'' type r for 98.00 + shipping
10 diamond audio d6 149.00 + shipping
10 inch infinty perfect 99.00 + shipping
The type R are lot cheaper then the Diamonds but if its worth it then I dont care!
Im still looking for anybody who has had experience with these subs
I have heard alot of good things about both what are the cons which one would aound better in a sealed box?
here Is what Im going to do im getting a new ported box regardless and for subs here is what I have found
I would rather go with something that is not main stream if posible has anyone had both the new type rs and the d6s
His amp is the RF 800.2
Perfect for the little D6's, or pretty **** close anyways
RMS Recommended onthe D6 is 400, IIRC
i think the rms is 500 hundred, anyways the d6's are great subs, out of those listed, i think they are the best with a good blend of sq and output
fcivc24
fcivc24
keys, fl / livermore CA
fcivc24
