what amp are you running and what size fuse do you have 18inches away from your amp? and no i can't type
i know i'm just hearing about some big amps on some small fuses just for burpsYour fusing is directly related to the amount of cone area you have as well.
is it the efficiency of the amps or your electrical?Sometimes I burp my 2 Sundown 3000's @ 4 ohm strapped on a single 5A fuse.
Don't forget about the Sonic, its still here and as loud as ever. I can use a 40a fuse with that1indatrunk: your not going to be in AS1 with a 18" unless your have a like 30a fuse, and in AS you HAVE to play music, no burps or sweepsjustbloud: how many subs do you have and size?
.......and the Op, JusBloud has 4 12" Type Rs sitting in the house, so he has some subs to play with1indatrunk: your not going to be in AS1 with a 18" unless your have a like 30a fuse, and in AS you HAVE to play music, no burps or sweepsjustbloud: how many subs do you have and size?
lol i forgot about that lil fvcker love to see you guys out there ripping **** up!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifDon't forget about the Sonic, its still here and as loud as ever. I can use a 40a fuse with that
thro them bishes in there and lets roll you guys going on the 22nd??.......and the Op, JusBloud has 4 12" Type Rs sitting in the house, so he has some subs to play with
I lose about 2 dB going to a 5A fuse, but it's still pretty loud. We have our little tricks If you spend some time in MECA you will learn a lot more about fuses than what most people on this site understand. Not everybody on this forum understands that what a fuse is rated for isn't always what it's able to handleis it the efficiency of the amps or your electrical?
