Are walls always louder?
Well i guess i gotta crap ton of port area. Might as well see how it goes lmao. Once electrical is done ill have 4k to throw at them.
I'd honestly throw in some 2x4s and shrink that port. With that much airspace and port area and power your subs will unload really quick and honestly you might burn your subs up. When i had excess amounts of port area in my old setup with adjustable ports, the subs did not like it at all with more power put on them. They smelled extremely fast. Literally in Infinite baffle situations the subs handle a lot less power which is what you'll experience. Keep shrinking the port until desired output is reached.
Ok, how would i position the 2x4s to shirnk the port?
So with a big port power handling decreases due to less internal resistance?
Im getting the 4k now incase i upgrade later but plan on lowering the gain initially so that im not overpowering.
yeah basically. Just you'll find that in order to get anywhere near acceptable modest volume levels, the sub might already stink.
Just pile it on and decrease overall port area thats all.
180 in2 of port area with 2 IDMAX 15's in a 8ft3 net box... wow
14,000 watts of signal to get it to 27 m/s?... That's a much too large port...
And it looks like you'll need 17K to get there... 14K
Looks like about 89in2 for a 4K amp in a 8ft3 net box with 2 Idmax 15's would work (that's tuned to around 35hz btw)...
You're gonna free air those subs with 180in2 of port and they'll most likely be bottoming out once you put the power on em'... I hope they got some KILLER suspension.
they have very soft suspension hence the low FS. He'll rip em apart.
Only way 180 port area would work is if he shrank the box to 2 cubic feet and did a burp box tuned to 45hz and play one note only lmao. Easy 150s.
Block off the slot port and use a 10" aero instead maybe... it'll be a 12ft3box... lotsa rise... IDK... might work?... tuned to 30hz it looks like it'll slam... for a 150 tho... no way
Might be rowdy tho... //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Looks like a 5K to get the velocities where I like em tho... a 4K might be a little underpowered for that 10"... what a mess
With a port that large you may never get the subs to move enough to "use" the port
Way too much port area can cause the subs to act like they are in infinite baffle costing a fk ton of output.
It's like people don't even understand how a port works.
http://jahonen.kapsi.fi/Audio/Papers/AES_PortPaper.pdf
Try reading what actual engineers who know what they're talking about have to say on the subject if you want to understand ports.
180"^2 port is probably overkill but it's not going to do any of the things these people say unless something is wrong with how you laid it out. If a port needed to have a minimum airspeed velocity in it they wouldn't work at low power which is simply not true.
If any port is fine stick a single 8" with 180" of port...
It will act like a infinite baffle that hasn't been sealed off and it will not get loud
It will also reach mechanical limits much faster than building a proper sized box and port
there is such thing as too much port
If it ends up being too much ill just cut 4 or 5 pieces of mdf the exact diemesions of the port wall and just add them one by one as needed. My internal volume is already what i want it to be.
KilluminatiDre
KilluminatiDre
Japan
KilluminatiDre
