Are the JL Audio 12W7 Specs too small?
It's not to the ideal recommendation. I think the 12" calls for 1.8cu, about. It won't make that much of a difference, and if they use fill, you'll be fine.
i think they are too small..look at the dims one the H.O box they make, its like twice the size
I believe you are comparing a sealed box to a ported one, in which case a doubling of the size is normal.
Just plug the speaker specs into an enclosure calculator, determine the alignment you want, and it will spit out the correct dimensions.
it was way too small for my taste. I didnt like it, it seem to peak at the higher freqs. I suggest bigger and tuned much lower than the specs. I missed the lows so I went back to sealed.
So what dimensions would you guys recommend? Length/Width/Depth? I'm a newb to this stuff, so tell me what size I should build it.
jmass03
jmass03
FL
jmass03
