jsluss17
or is wood glue really all you need to make one? its not a huge box it's 1.8 cubic feet so idk if ill need all that support
Let me actually answer your question. No you don't need screws or nails. They are for pressure to hold the panels together until the glue dries. You can use clamps if you want. I have done a 12 cubic foot net box without nails or screws. But normally now, I use titebond and clamps until I show some brad nails in the peices.or is wood glue really all you need to make one? its not a huge box it's 1.8 cubic feet so idk if ill need all that support
thats exactly what I do. glue, clamp, nail and move on to the next side. All the strength and hold comes from the glue so the nails/screws are just there to hold'er steady till she dries. Now if you ever need to remove a side closed cell foam and good quality coarse screws are a good choice and as said above remember to predrill. Remember to remove dust from the enclosure before finish as it can collect in the mechanical parts of the sub and make the heat situation and venting worse(granted not by much) And always make sure you have a 100% airtight seal on every side use ample glue/silicone/foam/or resin whatever it takes and then you have yourself a useful enclosure for years of enjoyment to come.Let me actually answer your question. No you don't need screws or nails. They are for pressure to hold the panels together until the glue dries. You can use clamps if you want. I have done a 12 cubic foot net box without nails or screws. But normally now, I use titebond and clamps until I show some brad nails in the peices.
thanks guys
Acrylic caulk will do just fine sir
