are amplifiers actually worth using?
take a look for your self.
you see the 2 red jumpers on the xover?
1 is for the tweeter + & -
other is for the dual driver setup, jumper for 4ohm & 2ohm.
thats why i left the jumper on the 4ohm
I see. Intresting. Put it on 2 ohm. When you connect 2 drivers, I am sure they are 2 ohms then, MAYBE its like that so you tell it that ur running 2 drivers at 2 ohm. Just try it and see. change that jumper from 4 ohm to 2 ohm.
Maybe its for a configuration that means 4ohm=1 driver. 2ohm=2drivers.
this is the problem i think, im not 100% sure my amps 2ohm stable?
Technical Data:
Power RMS / Musik at 4 x 4Ohm at 13,8 Volt
4 x 60/120 Watt
Power RMS / Musik at 4 x 2Ohm at 13,8 Volt
4 x 100/200 Watt
Power RMS/Musik 2 x 4 Ohm bridged
2 x 180/360 Watt
it does say that on the spec, but you get better sound quality from a 4 ohm
Technical Data:
4 x 60/120 Watt
4 x 100/200 Watt
2 x 180/360 Watt
Not that you would notice the difference between 2 and 4 ohms. It'll be a pretty negligible change.
m^ke
m^ke
leicester
johnecon2001
