are amplifiers actually worth using?
m^ke
the reason im asking this is.
i have recently gone from unamped 5.25" in-phase component speakers to amped dual 6.5" components. when i say dual, i mean, 4X 6.5" components, 2 to each xover.
dont get me wrong, they sound nice, & the midrange couldnt be any better, but it just dont seem to be any louder.
i thought the whole point in getting new higher power speakers & amping them up was so you can have them play louder?
heres some details....:
Flexible 2-way frequency crossover with:
tweeter level adjustment -3 / 0 / +3 dB with gold plated repositionable jumpers
4 ohm / 2 ohm switchable for the operation of two woofer systems
integrated tweeter protection
Technical Data:
Power RMS/ MAX.
60/ 80 Watt
Sensitivity
90 dB 1W/1m
Frequency range
50 Hz - 21 kHz
& heres the info on the amplifier, its currently in bridge mode.
Technical Data:
Power RMS / Musik at 4 x 4Ohm at 13,8 Volt
4 x 60/120 Watt
Power RMS / Musik at 4 x 2Ohm at 13,8 Volt
4 x 100/200 Watt
Power RMS/Musik 2 x 4 Ohm bridged
2 x 180/360 Watt
Total harmonic distortion
Signal to noise ratio
> 93 dB
Bassboost adjustment
0-18 dB
Frequency range Highpass
15 Hz-4 kHz
Frequency range Lowpass
40 Hz-4 kHz
Frequency range Bandpass
15 Hz-4 kHz
Frequency range
10 Hz-30 kHz
TIM distortion
Input sensitivity
200 mV - 8 V
Fuse
2 x 25 A
Input impedance
10 kOhm
Dimensions (H/W/D) in mm
64 x 245 x 400
Weight netto
4,6 kg
my stereo is a sony stereo & thats 4X50W so it seems that theres no need for a amp? or i have made a very big mistake in buying lower RMS speakers?
plus the amp gets RED hot to touch, i mean realy hot, that you carnt touch it.
any help in this matter? im starting to feel that i have waisted alot of money on this kit.
no helix dark blue 4
http://www.audiotec-fischer.com/englisch/produkte/endstufen.html
the components are also helix precision H236
the amp should be about correct for the speakers, the sound is awesome, midrange vibrates the car.
when i play dia straits its sweet as a bell, but any other type of music & its realy not to clever, i carnt play it as loud.
this is why im thinking that theres no point in useing amps, only to power a sub in the rear...
cos theres no benefit from it, & it only costs money in buying the cabling & the amp in the first place,
you might aswell just buy new speakers & run them on the HU, as the amp wont make the speakers sound any louder.
thats easier said than done, i have just spend at least 20 mins reading "how to set gains" & "amplifier settings" & they contradict themselves....
how do i set it up right then? & is it even possible to set right? as all types of music is different from each other, & the music them selfs are different.
yes, 4ohm, i can change the jumper on the xover to 2ohm, or leave the jumper on the 4ohm.
the xovers have just the normal "input" "woofer" "tweeter" on there, so i have wired 2 speakers to one xover. & just left the single tweeter on the xover.
im thinking as i have left the xover jumper on 4ohm, itll be 4oh.
or am i missing some thing here?
Good speakers and amps are transparent. They don't care if the music is different, they only reproduce what they are given. The likely reason that they don't seem as loud is either because as suggested things are not set up correctly or that the lack of distortion makes them seem like they are not as loud because they don't hurt your ears.
You're missing something. It doesn't work the way you seem to think. You can wire the pair of mids to the crossover but unless the crossover is configured correctly it will not work as it should and the division frequency will be totally out of whack. In addition, if you have two mids wire in parallel, the amp will see a two ohm load at the freqs where they are playing. Chances are that your amp isn't going to like that 2 ohm load when bridged.
20 minutes isnt really that long.
Are there any reputable shops around you?
Maybe a forum member?
m^ke
m^ke
leicester
johnecon2001
