AQ1200 at 0.5 ohm?
Specs say "NO"
Specifications
Model AQ1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V—16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dash Mounted Remote Included
Lame..... Oh well I suppose what about on the 2200? what kind of power at 0.5 ohm would one expect?
I didn't say the aq1200 couldn't do it, It voids the warranty, and could possibly cause problems for it. I ran my aq1200 at .5 for about 10 minutes testing a Btl out, didn't seem to lag up and such, and not that the clipping light on the bass knob is accurate at all, it didn't go off.
Well, It will only be 30 seconds at a time. Do you know what kind of power you were getting out of it at that time?
No 100% sure, but Id say i was giving a 1100 watts, over 1000 watts for sure. Subsonic up to around 27hz, lpf allowing a 0hz to 55 hz, and gains fixed on my headunit voltage.
Just be easy with it, burping, I guess you could do it, just know what the consequences could be if you don't have the electrical to back the amp up.
So, do you think I would have better luck with running a dsc1500 at 0.5 ohm? To be honest I am looking for something that will be around 800-1000 at 2 ohms and 2000+ at 0.5 ohm.
You will not get 2000 out of an aq1200.
Why not invest a little more and get the aq2200? Alot easier, and well worth it. Plus, it can defintely take it.
I was eventually going to get another aq1200 but it probably isn't cost effective. How much would an aq2200 put out at 0.5 ohm?
Another aq1200 added to your current one would be 2400 watts.
An aq2200 is just at 2200 watts. Solid 14 volts will make it put out anywhere around 2400-2500. Read their website, it tells you.
But once again, make sure you have the electrical to back this up, or you can damage your car battery, alt, and amplifier.
30 sec is a long burp lol. as for aq1200 if your electrical is good shouldn't be an issue but will not be 2k maybe 1600 or so. ive ran a 2200 and 3500d's daily at .5 just because its wired at .5 dont mean its seeing it you have to account for impedance rise.
Ge_off_me
Parts Express Specialist
Ge_off_me
Enon, Ohio
d-REW
