apsm 1500
Curren$y
is randomly going into protect mode on many different bass notes
set up is 2 12" re audio sexs dual 2 ohm, 4ga ofc knukonceptz, there is no paint where i grounded my ground wire, completely stock electrical, amp is running @ 2 ohms
what could be the problem please help //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
probably low voltage. being audiopipe does not mean anything besides it being a cheap amp
Are you sure you have your gains set up correctly? Check to see if your grounds are loose also.
I haven't because don't have dmm so I'll get one. I just recently went it and retightened all of my connections. Any more suggestions? Thanks
Hey sorry for the super late reply but yes I'm wired at 2 ohms for sure. Another thing I noticed is that the amp is not even hot when it's clipping. If you guys can't think of anything else can you point me in the direction of maybe an audioque or any 1200-1500 Watt that isn't trash?
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
423
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
662
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
912
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
Curren$y
Curren$y
Dallas, TX
Curren$y
    May 24, 2024
