Apsm 1300 stopped working???
Mr.meyhem
Ive had it for less than a year. I hooked my sub up to my speaker amp to see how I would like the comparison of the two amps and then when i hooked the sub back up to the apsm it was in protection mode and the power light was flickering. i didn't change any setting on the amp. so why did it do this??? hooked it up to a dmm and it read 0 from the 12 v to the ground on the amp...
I'm very confused on what to do. could this be a factory flaw and would be cover by warranty or am i SOL?
Have you checked your fuses?
yeah fuse is good. i have it split off a distro to my speaker amp and that works fine. even tried unhooking everything and redoing it all and it still didn't work. i hooked it up directly to the battery when i used the dmm and it read 0. so its the amp //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
was the amp on then you disconnected the sub wires...or did you unplug the RCA patch cables with the amp on?
car was off when i took the sub wires out and put them back in. but when i took them out my fuse was still in. it was out when i put the sub wires back in tho.
Mr.meyhem
Mr.meyhem
Cold as F***, MN
BIGJEFF64
