Apsm 1300 stopped working???
If you take it back to a dealer, it is is my understanding that they will give you your money back on the 1300s, they had some internal component issues that none of the other models did.
how did u disconnect and reconnect the amp? what i mean is even with the car off in what order did u remove the wires? cuz it sounds to me like u grounded the amp which if enough current goes through will not pop the fuse and ull be screwed
12v ground and rem along with rca's stayed in the whole time. i took out the positive speaker then the negative speaker and had it running like that with my bass knob down all the way while i was running the sub off my other amp that was also hooked up the whole time. then when i hooked the sub back up to the apsm i did negative then positive and yeah protection light was on...
---------- Post added at 11:55 PM ---------- Previous post was at 11:54 PM ----------
good to know. i got it off ebay brand new. so idk where the closest dealer would be?
Mr.meyhem
Mr.meyhem
Cold as F***, MN
BIGJEFF64
