apline MRV-M500 - Causing spark when I connect speaker wire to subwoofer
SeanTX
I have an Alpine MRV-M500 powering my subwoofer - Have checked ground connections, and everything else I can think of but when I connect the speaker wire I get a spark from the connection. Then, when I turned on the radio, the voicecoil started MELTING!!! Please help, not sure what else I can test to isolate the issue.
sounds really weird, possibly its an amp issue, use a DMM and set it to AC V, look for anything unusual while playing a constant bass tone (DO NOT HAVE SPEAKER HOOKED WHILE DOING THIS)
That can happen if you are hooking up speaker wire while amp is on.
Is the amp on when connecting the wire? If so, you can damage the amp doing that.
If the amp is doing that off, then sounds like it's damaged internally and can cause parasitic drain in vehicle.
You also mention the voice coil starting to melt.
If the voice coil is melting, what is happening to the tinsel leads?
If you are going to measure output voltage, you might want to set it to DC Voltage because this kind of issue sounds like the amplifier is no longer putting out an AC signal.
I may be interested in it. Pics would help.
I would swapp one of the front speaker wires on the amplifier to test the rear amplifier to test to see if they work/testing that way on each rear...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG.16,2022 @9PM CT. THANKS
  • Locked
That MRD is a good series of amps ...i may have some extra accesories if you havent found them
SeanTX
SeanTX
Dallas, TX
shizzzon
    May 12, 2024
Brendon Jenness
    May 11, 2024
