Apexi JR super woofer 8"s ported 1.75 cubes @ 34 Hz build
they only need .8 cubes ported, .5 sealed
8 moofers, 4 cubes,
6.4 cubes + poart, ain't bad, considering it will SLAP
where did you get those specs?
my box is .6 +port.
I think going bigger then that will cause this bishes to bottom out to much.
**** theyre 165 a piece, are there any, that are around 100 a piece? Maybe 110?
What If I dropped 4 of them into an enclosure like the one this guy has
You could also do 4 DD 1508's. You can find them use on here for around $125-$150. I have 2 RL-i's in the wifes car, and 6 1508's going into my blazer.
The tweeter has to be crossed over somehow. Doesn't matter if it occurs at the HU, the amp or passively.
915
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
856
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
GAM3OVR
Jeka is Back
GAM3OVR
Russia
GAM3OVR
