ap30001d wiring?
You can run it bridged @ 2ohm or run each channel @ 1ohm. Bridged you can safely run the amp down to 1.3ohms, each channel can be ran safely @.5 daily.
you think thatd be good then doing it bridged even though its 2 ohm minimum?
it would be at 1.5 but theres gunna be some imp rise so it would be close
Nothing wrong with those amps at all. You must be one of those guys who pays for customer service//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
it will be fine dude i was making a joke lolz. with decent electrical they will do 1.5 easy.
i know someone right now running 1 at 1.33 dialed in at 51.65 volts for 2kw exactly after rise to 6 hfi 12's in a wall doing more flexing db than he did with 2 18's on 5kw so it will handle it with good juice.
Won't take that either. Run it at 1.5ohms bridged and be done, just turn your gains waaaay down. I've had 3 12s and 1 10, all on a MTX1501d. None of them liked that amp for extended periods
it will be fine dude i was making a joke lolz. with decent electrical they will do 1.5 easy.i know someone right now running 1 at 1.33 dialed in at 51.65 volts for 2kw exactly after rise to 6 hfi 12's in a wall doing more flexing db than he did with 2 18's on 5kw so it will handle it with good juice.
oh nice. so you think both of them would handle it ok?
blabo219
blabo219
Battle Creek, Michigan
Annnarbor84
